FMIC questions
Old Feb 13, 2005 | 11:30 PM
Weedo's Avatar
Default FMIC questions
When you bought your FMIC, how did you fab it up to work? What tubing did you use? How did you "weld" it or clamp it together? I'm trying to figure out how this works with aluminum. How did you know what size to go with? Brand? Etc?
Old Feb 14, 2005 | 12:29 AM
You should purchase end tanks that match the piping you plan to use in your vehicle. Like radiator hoses, there are various diameters and angles available. Basically you weld those end tanks to your core, and go racin'.
Old Feb 14, 2005 | 12:34 AM
F8L Z71's Avatar
If your IC has 3" openeings then you go with 3" tubing. It's kinda like a puzzle really. You just figure out where you wanna mount the IC and make sure you can get piping to it. Then figure out how many bends you need and what kind. Then you have fun mocking up the piping and measuring before you cut. Some actually go to the extent of using PVC to make the tubing then when it's all finished they can simply measure the PVC and then cut the real tubing to match.
Old Feb 14, 2005 | 12:41 AM
chris99gmc's Avatar
use mandrel bent piping and high temp silicone fittings with clamps.
JordanH
Dec 25, 2015 08:32 AM
1slwgto
Oct 1, 2015 01:51 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
