FLP level4 and SS3800 in! Got an SES!
Old Nov 13, 2003 | 08:45 PM
Black Blown 02's Avatar
Default FLP level4 and SS3800 in! Got an SES!
Drove it for about 10 minutes, everything was fine, then I get an SES.
After the SES tripped, I had no overdrive or converter lock-up.
Scanned it with EASE and it was PO757..2-3 shift solenoid stuck on.
What do you guys think, bad solenoid? Came unplugged? Any ideas? Is it in the valve body accessible by removing the pan?
Thanks.
Old Nov 13, 2003 | 09:39 PM
GMC SKI's Avatar
Maybe unplugged or a bad
If you turn off the truck and start it back up again does it go back to normal ?
Clear it and see if it comes back
I've had my issues with the solenoids gettin stuck open
GMC SKI's Avatar
you can access them by dropping the pan
Old Nov 13, 2003 | 09:56 PM
StupidFast's Avatar
This code is normal with that loose of a converter. I get the code about once every 3 to 5 weeks, so does my buddy. Clear the code and forget it. It will disable 1st and 4th gear, as well as the TCC. I finally got smart and deleted the code with my LS1 Edit.
I think it happens when the transmission is shifting and I let off of the throttle. It is hard to tell. Enjoy the converter.
Old Nov 13, 2003 | 10:01 PM
That makes me feel so much better!!
Also the fact that it disables 1st gear. I was thinking, man this converter is loose!
I'll be deleting the code right away
Thanks Stupidfast
Old Nov 13, 2003 | 10:11 PM
parish8's Avatar
single digit dreamer
this board and it's members are the ****, it took all of one hour to figure out the problem and know how to fix it! sounded like it may have been a significant problem and turns out to be nothing
Old Nov 13, 2003 | 10:32 PM
If it werent for this board, and members, I would've been calling FLP tomorrow, or dropping the pan inspecting the shift solenoids.
Old Nov 14, 2003 | 03:30 PM
BlownAlaskan's Avatar
Hey BLack,
give us a report on your new setup. I am saving up right now for a tranny and converter. I am starting to think that this is the only option for the procharger. Launches are a joke!!
Old Nov 14, 2003 | 06:14 PM
Flyer's Avatar
If it weren't for this board .. I would probably have about 7-9 grand still burning a hole in my pocket still. Wouldn't have near the knowledge or fun driving around though ..
I'll agree .. the knowledge on this board is unbeatable!
Old Nov 14, 2003 | 08:34 PM
Okay, reset the code and turned it off with edit, everything works perfectly now. Stupidfast, YOU DA MAN!
As for impressions of the converter and trans, I'll start a new thread.
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
JCW
Sep 22, 2015 03:59 PM
rojeho
Aug 8, 2015 07:20 PM
parish8
Nov 17, 2003 01:57 PM
