floating
Old Oct 20, 2007 | 10:54 AM
454navyss's Avatar
Default floating
at what RPM do the valves start floating with stock valve springs? thanks.
Old Oct 20, 2007 | 12:03 PM
ZZebes's Avatar
wit boost 5kish
without 6500ish
Old Oct 20, 2007 | 12:24 PM
454navyss's Avatar
excellent, thank you
Old Oct 20, 2007 | 12:29 PM
454navyss's Avatar
what RPM will a stock motor hold safely? i have bolt ons only
Old Oct 20, 2007 | 12:37 PM
ZZebes's Avatar
6100K without Rod Bolts
6500K With Rod Bolts
Old Oct 20, 2007 | 02:29 PM
BlackLM7's Avatar
I have no real world experience with this. Some members on this site said they can spin 6200 RPM's on a stock bottom end 5.3 with no problems. They hit these RPM's quite often too. I'm pretty sure bluecajun5.3 said this before.
Old Oct 21, 2007 | 12:35 AM
Quik's Avatar
5 year bitches!
valves can float at an earlier rpm as well. dpends on mileage and etc
as for what rpms. its reasurance but ppl including myself have rev'd a motor 7k without issues for periods of time
Old Oct 21, 2007 | 12:39 AM
TouchOfEvil04's Avatar
I turned my truck to 6200rpms on the 5.3 with bolt ons only for a good while.
With my 6.0l with 918springs i turn it to 6700rpms no problem.
Maybe with the new heads i'll be able to turn a little more...
Old Oct 21, 2007 | 11:25 AM
Flyer's Avatar
I ran a stock 5.3 (with rod bolts) up to 7k on a regular basis. It wasn't the bottom end that was the problem. It was a wrist pin in my case.
With the right springs, intake and cam, I would do it again without question.
Old Oct 26, 2007 | 09:35 AM
454navyss's Avatar
would a set of z06 springs be a wise investment?
