First build 6.0 help with parts list.
Old 02-07-2013, 03:05 PM
BigDaddy0381's Avatar
This is a LQ4 if that changes anything.
Old 02-07-2013, 03:37 PM
TXSZ66AVLANCHE's Avatar
Originally Posted by BigDaddy0381
okay, thanks. so if I went with dish pistons and a .030 mill I would still work out about the same CR correct?
Your starting to split hairs here...
Old 02-07-2013, 03:40 PM
Yes it does change things, if you have a LQ4 go with the 243/799 heads then.
Old 02-07-2013, 05:13 PM
61.1cc would give me around what CR with the 799. My mind is trying to grasp what is what.
Old 02-07-2013, 05:29 PM
799 heads are 64.5 cc, not 61
Old 02-07-2013, 05:33 PM
Mine are the sdpc cnc 5.3 heads. Site says 61.1. I was going by that. Looks to be 862 casting.. my bad...
Old 02-07-2013, 08:01 PM
10.5:1 lq4 with 4.00 bore
Old 02-08-2013, 06:38 AM
Okay, sounds like it might work out unless I have to punch it out some. so here is what I'm looking at so far. anything I need to add. This is my first build and I'm clueless at what i need for this point.anyone want to take a guess at HP/TQ
Lq4 block
stock crank/ rods/ pistons (dish)
862 heads 61.1CC with 10.5.1CR
Comp 54-455-11 Camshaft
LS2 Chain
16 GM LS Rocker Arms
Comp Trunion Upgrade Kit
LS7 Lifters
LS2 Trays
APR head bolts
Manley 7.400" Pushrods (length can be changed)
PAC-1211X .625" Valve Springs - Beehive
I hope I can use alot of the sensors off the 5.3 I have now. I'm guessing it will all swap over.
Old 02-08-2013, 02:07 PM
any more thoughts?
Old 02-09-2013, 08:52 AM
K, look like a Lq4 block ls3 piston and rods with worked over 317's. Any thoughts on a cam?
Quick Reply: First build 6.0 help with parts list.
