first 408 dyno report
Old Jan 16, 2005 | 11:09 AM
  #21
parish8's Avatar
single digit dreamer
Originally Posted by NOSjohn
I think you are correct on the wheel slip. Like I said, a set of sticky tires can help but I forgot to mention, due to being so late at night, that you might want to load the back of the bed with sand bags or cinder blocks.
the rear axle had a HUGE load on it. there were straps directly over the axle pulling it strait down. if you look close at the vid of the rear tire you can see it jumping around a lot. we tried 26psi, 32psi and 40psi and none of that worked.
Old Jan 16, 2005 | 11:19 AM
  #22
NOSjohn's Avatar
Restricted User
Ya, I noticed that, very odd.
Old Jan 16, 2005 | 11:21 AM
  #23
moregrip's Avatar
what a rush!
seems like you really need a quality wheel/tire combo, have you figured out what you want yet?
Old Jan 16, 2005 | 11:30 AM
  #24
parish8's Avatar
i know exactly what i would like to have. but will likly choose something cheaper unless i can get a good deal. the 305/45/18 nittos
Old Jan 16, 2005 | 11:31 AM
  #25
gonzo 6.2's Avatar
Is your G-tech telling you anything about the gains?
Old Jan 16, 2005 | 11:34 AM
  #26
moregrip's Avatar
what a rush!
Very Cool, If anyone needs a good set, it'd be you. That's a great combo.
If you go the less expensive route, you will you still get the wide, sticky rubber? And maybe go with a less expensive wheel?
Old Jan 16, 2005 | 11:38 AM
  #27
NOSjohn's Avatar
Restricted User
Jim, I can check and see what my cost is on those and get back to you with some sort of deal.
Old Jan 16, 2005 | 11:48 AM
  #28
parish8's Avatar
yes, right now i think that is the best rubber for my set up. i wish they were taller or even better yet those new mt dr's but 29+" tall.
Old Jan 16, 2005 | 11:51 AM
  #29
parish8's Avatar
check it out. they dont list a 18x9.5 but they make them, not sure on the back spacing or even what is availlble. hook me up man!
Old Jan 16, 2005 | 12:10 PM
  #30
NOSjohn's Avatar
Restricted User
So, you want 4 wheels, all the same size, but 2 drag radial tires in size 305/45-18 for the back wheel only? I'm on AIM too - GNjohnny5.
