Finally started the 6 liter... Runnin on 5 cylinders?
Old Sep 30, 2009 | 09:18 AM
LS1FREEK's Avatar
13 Second Truck Club
Unhappy Finally started the 6 liter... Runnin on 5 cylinders?
So i finally started up my 6.0 liter last night and it only ran on like 5 cylinders! I checked for spark and it was all good. My conclusion? Injectors.. The engine sat for 4 years before i bought it, so i cleaned the injectors as best i could with some carb cleaner cuz they had some gunk in them. Anyway a guy i know told me he soaked his injectors in some solvent over night and blew them out with compressed air. But that sounds to me like it might be a little hard on them. Or what do you guys think? I was thinkin of buying a couple bottles of injector cleaner that you put in the gas tank and soaking them in there.. O and does it not hurt the electrical part of the injector if soaked in something like that?
Old Sep 30, 2009 | 11:32 AM
pewterliftedz's Avatar
acdelco sells a very heavily concentrate injector cleaner that we used to sell to shops... they would soak them for a couple of hous and clean them off with carb cleaner.. let me try to find you a part#...
edit: i think the part number is X66P
Old Sep 30, 2009 | 11:37 AM
budhayes3's Avatar
PT's Slowest Truck
I'd be concerned about submerging the electrical portion of the injector myself...
Old Sep 30, 2009 | 11:42 AM
Daryn's Avatar
Formerly darynC-10/23/10
why not use your 5.3 injectors? they are the same i think
Old Sep 30, 2009 | 03:45 PM
LS1FREEK's Avatar
I thought about the same thing already but i have always been told that the 6 liter injectors are bigger than the 5.3's. I am going to check the part numbers when i get home tonight. I dont know why i didn't do that before i installed them lol...
Old Sep 30, 2009 | 03:48 PM
GMCtrk's Avatar
Same exact 24.7s
Old Sep 30, 2009 | 03:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Use your 5.3 injectors. They are the same.
Old Sep 30, 2009 | 04:49 PM
turbosilvi's Avatar
if you do soak the injectors, dont let the electrical part get in the solvent or gas or whatever your using. could cause malfunctions or if there is for some reason a loose wire and it sparks, you could have a problem. just my opinion. but dont use compressed air on the injectors, it can damage them. i know from personal experience (i did it to my stocky's that a friend needed when i was installing my 44's, i ended up crackin one of the injectors and the metal plate with the 3 holes where the fuel comes out..... ya, it came off! thats one mistake i wont do again. and i dont know if the 5.3's are the same, but if these guys say they are, id believe them. good luck!
Old Sep 30, 2009 | 05:54 PM
LS1FREEK's Avatar
Hey thanks guys! I'm going to try the 5.3 injectors tonight and i'll check the numbers to see if they are the same or not... I'll post up when i get it running.
Old Sep 30, 2009 | 09:14 PM
budhayes3's Avatar
PT's Slowest Truck
The injectors are the same...the part numbers may not match though. 00-07 classic 4.8,5.3, and 6.0 injectors all flow 24.7 lb/hr (99 is 19 or 21 lb/hr). Not sure on the NNBS's though. My current injectors are from an 02 6.0...
