Finally installed LT1 fans & ASP crank pulley >>
Old May 17, 2003 | 03:41 AM
INDIGO 5.3's Avatar
Default Finally installed LT1 fans & ASP crank pulley >>
I went to pewter 4.8's house right after work and installed my LT1 fans and an ASP underdrive crank pulley. I got one word...WOW!!! The torque management is killing me now, I am having Allen at Nelson performance remove all of the TM Monday. Hopefully I will notice even more of a difference with the TM removed and let me take more advantage of the engine power. Any opinions??
Old May 17, 2003 | 10:56 AM
Hit Man X's Avatar
Default Re: Finally installed LT1 fans & ASP crank pulley >>
Is the TqMgt that bad already?
Ah well, you did pick up close to 16rwhp, not too shabby.
Old May 17, 2003 | 11:34 AM
INDIGO 5.3's Avatar
I was punching the gas and running it through 1-2 2-3 then would let off. I did this numerous times. The more I would do it the more it would fall on its face between shifts! Oh well, TM will be removed next week anyways
Then we will see if there really IS a difference with the TM removed.
Old May 17, 2003 | 11:46 AM
Hit Man X's Avatar
Cool, should make a difference going from to
Hopefully I should have some homes closing by months end, and will order me some Stall and Edit as well as get my TransGo and servos in. Then my truck will be able to move out of its own way! hahhahaha OR I could spend a few $$$ on the WRX too... mmmm booost.
Old May 17, 2003 | 12:24 PM
SleekSilverado's Avatar
How exactly do you remove the tq management??? Would a peradator take care of it??
Old May 18, 2003 | 02:02 PM
anyone know???
thunder550
Oct 8, 2015 04:53 PM
bigsapper
Jul 28, 2015 12:56 AM
blownss27
Jul 20, 2015 08:59 AM
