finally got me a cold air intake
Old Jul 15, 2006 | 09:57 PM
moregrip's Avatar
what a rush!
Not a big fan of blowers but they do sound schweet when they are singing
Bout damn time you stopped chocking that thing
Old Jul 15, 2006 | 09:58 PM
moregrip's Avatar
what a rush!
Originally Posted by TIM Z
holy jeez thats a big filter. does the shield block air that you might get if you took your headlight out? BTW i notice a stain on your coolant reservoir, mine has that stain also, whats up with that? sorry to get off topic your pic made me think of it.
if I take the headlight out, yes that part would be open for a direct blast. LOL, That stain bothers me too, I haven't investigated it yet though. Probably just needs a good cleaning
Old Jul 16, 2006 | 09:06 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mine has the same stain also but my truck has quite a few more miles on it (185K)
Old Jul 16, 2006 | 09:20 PM
dewmanshu's Avatar
Moderately Differentiated
maybe one of the gm tech guys will chime in if it's true or not, but I heard...ready for this...it is common on mid mileage vehicles as far as gm says. Whatever the hell mid mileage is. High mileage and the resevoir should start to fog up heavily.
Hooray for not "choking the radix"! Keep the chicken jokes to yourself!
Old Jul 17, 2006 | 12:22 AM
gmtechnician's Avatar
i dont know about what gm says but your coolant system has what is called the "beach head" affect. This is like at the beach the tide brings up trash to the highest point that the water will go and then the water will go back out leaving the trash. That is like the coolant, all the corrosion in the system will flow till it finds the highest point and then kind of be "washed up" and left. This is why you see all the coolant tanks and older style radiator caps dirty.
Maybe this will help.
Old Jul 17, 2006 | 01:55 PM
moregrip's Avatar
what a rush!
excellent info, is this "beach head" easy to clean out or does it even matter?
Old Jul 17, 2006 | 02:45 PM
04Denali's Avatar
Originally Posted by thunder550
What did you do to make your stock Radix intake tube work with the 90mm tb?
My stock Radix tube fit my 90mm TB perfectly
Old Jul 17, 2006 | 02:52 PM
dewmanshu's Avatar
haha awesome info. So my guy was right. Expect staining due to all the bad stuff floating up.
Old Jul 17, 2006 | 03:15 PM
thunder550's Avatar
High on diesel fumes
Hmmm maybe mine is different because it's an aftermarket throttle body.
Old Jul 17, 2006 | 04:38 PM
you can clean it all you want, its just going to come back. just whatever makes you sleep at night
