Finally got to Install!!!
Yes they are the ceramic coated pacesetters. Today I am going to take the bolts out clean them up and put anti-seize on them plus I am going to paint the muffler with VHT flat black header paint. I'll post pics of that also.
Alright so I went and got some anti-seize and removed the header bolts one-by-one and coated them with it. I also figure why I was at might as well do the spark plugs also. So is all done and good to go.
Now I am in the process of painting my muffler. I'm waiting on the primer to dry. Pics are soon to come.
Are those the clamps that come with the headers or did you get them somewhere else? The reason I ask is I just ordered the same headers and y pipe. Also what did you put on the slip joint before you clamped them, it looks like hight temp permatex and aluminum foil.
Those are clamps that I order not the one that come with it. I order the stepped band clamps but they wont work on the passenger side b/c of the O2 sensor. So what I suggest and did was on the passenger side slip joint I used a flat band clamp. It molds to the pipes and seals up rather well. I would grab you a couple 3" flat band clamps and go to town. For the other slip joints I just used what they sent until today when I took it to the muffler shop and had them weld it up for a good seal. But band clamps will work there also. The piece with the flange that slips onto the part where the y-pipe merges I would get welded, I don't think a band clamp will work there.
To get a good seal I just squirted some hi-temp copper based RTV before I slid the pipes together and wrapped a piece of foil around the joint and clamped it down snug. I haven't had any leaks yet at those joints. I am very happy with the results of the install and performance. You will be also.
BTW I got all my ideas from people on here. I have another thread that talks about installing them also: https://www.performancetrucks.net/fo...d.php?t=437752
Alright here are the pics of my muffler paint job. I just sanded all the rust off, first hit it with a coat of cheap rattle can primer, then I did three coats of VHT High-Temp Flame Proof Flat Black Paint (it is in a rattle can also).
Muffler Before:
Primed:
Painted:
Muffler Before:
Primed:
Painted:
