f'in headers!
Old Nov 4, 2006 | 03:46 PM
stone150's Avatar
Default f'in headers!
let me ask this when you drive with passetteres( those who have them) do you hear more engine noises than you did before, bec i hear the typacial exaust but i hear other noises.
i think they are leaking i had collector flages welleded on and the other 2 joints welded. but i can still smell exaust sometimes. could the gasket in the collctor lfange be leaking? i was thinking of useing alot of copper rtv and anew gaskets, will this work? thanks
Old Nov 4, 2006 | 03:48 PM
LesPaul's Avatar
did you get the ORY too.... if so get used to it... exhaust is going to smell rich as hell without cats.... they are noisy too... more of a raw mechanical sound.... turn the radio up
Old Nov 4, 2006 | 04:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The exhaust wont smell rich if its tuned right. You will hear more engine noise thats jus thow it is will lt headers. Go with some thick copper gaskets or go with a header buddy setup then you for sure wont have any leaks.
Old Nov 4, 2006 | 05:42 PM
budhayes3's Avatar
PT's Slowest Truck
Just as slow said, even if the exhaust is sealed tightly, you will hear more of the noises that the engine makes. The thinner walls of the headers combined with better scavenging will actually amplify the internal engine noises...not to mention make your exhaust tone change.
04BlackGmc's Avatar
10 Second Club
yea mines the same way.. too rich i need a better tune.
Old Nov 4, 2006 | 07:46 PM
02sierraz71_5.3's Avatar
Its not in the tune, you just dont have the cats burning off alot of the excess exaust plus most of us without cats have aftermarket cams with alot of overlap and that plays havoc with the 02's. Get used to the smell.
Old Nov 4, 2006 | 09:10 PM
FarmerBeau's Avatar
Sexy Party Mod
Remember what i said about it echoing? Its gonna smell like exhaust because you have no cats. I say, just embrace it.
Old Nov 5, 2006 | 03:40 PM
stone150's Avatar
well at idle when i get under it i can't smell anything, but if i have my GF rev it up while i am "sniffin" i can kind of smell something but only intermittentaly. it is just really annoyin g about every stop i come to i can smell it and as soon as i get out of the truck i can smell it too. plus when i am in the truck i get a headache
Old Nov 5, 2006 | 03:49 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Light up a cigarette and crawl under there while its running. If you suspect a leak let the smoke rise up over the connection and see if it blows away or gets disturbed. Of course it cant be breezy outside. Best bet is to pull into the garage and try it. A headache indicates an exhaust leak. Unless youre 1Slow01Z71, then its probably brain damage.
EDIT: If you have any fuel leaks the above idea is BAD!
Old Nov 5, 2006 | 09:05 PM
stone150's Avatar
here i made too clips, i was trying to catch the other noises but my camera sucks oh well.
vid 1
vid 2
