Figured out why the 60e kept dying
In case ya'll haven't kept up, I had my truck flashed at the dealership a while back to get the so called latest and greatest flash from GM. After everything got straightened out with the tune issue and EDIT not being able to see it. I finally drove it off in a limp mode. It took me forever to get it running decent after that.
Anyways, shortly after I finally droveit out of the service department (that's where it stayed while I got the EDIT stuff figured out with the new segment1 ID), the tranny gave out on me in short order. When it went out it felt like it just missed a shift when it went for 3rd. After it did that once, it never worked after that.
I had that one rebuilt, the builder said in fact the 3/4 clutch set was burnt up pretty bad. Anyways, a rebuild later I put the trans back in ready to go. WIthin 500 miles it does it again. Same exact thing. It just felt like it missed a shift and went into neutral. This is the time it sat up for a couple months 'waiting to gather all the parts'
when I decided to go ahead and do the 80e swap.
I had a feeling after the trans did the EXACT same thing the second time that it wasn't the trans, but the tuning or programming in the PCM.
Yesterday I decided to do a little tuning on the truck to try and iron some kinks out and get the idle a little better. I reflashed the PCM with an updated file and go for a test drive. I was easing down the street, still trying to get the laptop up and running. About half way to the end, the trans feels like it went into neutral. I come to the end, and go around the block to verify. Sure enough ... the SAME exact thing that was going on with the 60e's.
I go ahead and get back to the house and put the flash I just overwrote back on and go for another test drive. Everything tested out just fine. I made a couple runs at part throttle-heavy throttle runs to start off. Then I made another couple of runs WOT all the way up to about 110-120 and it held good the whole time.
Moral to the story, I really think the 60e I had would stand up to the power no problem. It had way to clean of a shift to be questionable. I knew this when I was having all the troubles, but I didn't have any proof to back it up until now. So ... if anyone wants a damn good tranny ... PM me.
when I decided to go ahead and do the 80e swap. I had a feeling after the trans did the EXACT same thing the second time that it wasn't the trans, but the tuning or programming in the PCM.
Apparently it would shift into 3rd, but with somethjing like 0 line pressure. I can only assume that it hitting 3rd gear and 'free wheeling' with the clutches even partially applied, it toasted them in short order.
But why would it just go in to neutral.Im a noob when it come's to tranny, or lsi edit..
