Fenderwell Headers
Old Nov 10, 2014 | 05:51 PM
Brian_17's Avatar
Default Fenderwell Headers
2001 GMC 2500hd, Does anyone know who might build a set of fenderwell headers? Minimum 2" diameter, I can assemble the kit if someone makes it. Ive been al over the web and can find anything.
Thanks
Old Nov 10, 2014 | 06:30 PM
dirt track racer 81's Avatar
Nope.
Old Nov 10, 2014 | 06:35 PM
Brian_17's Avatar
Looks like I will be building a set or having a set built then........
Old Nov 10, 2014 | 07:35 PM
Why are you puttin on fender exits on a hd?
Old Nov 10, 2014 | 10:03 PM
pewterliftedz's Avatar
Ummm huh???
Old Nov 11, 2014 | 02:12 AM
Suburbazine's Avatar
If you're just looking for fender exit exhaust pipes, flip the stock headers upside down and run the exhaust pipe from the front of the engine back.
Old Nov 11, 2014 | 08:07 AM
Brian_17's Avatar
Its a pro street pulling truck. I am losing horsepower with regular long tube headers, and I hate the thought of cutting the hood up to make holes for upright headers. I will try to get a pic of the truck posted here in a few. We have dynoed the engine with long tubes, and fenderwell headers both and the difference is enough I want to find a set. The problem is no one is making them, so I need to buy pipe and a bender I guess. I can buy the flanges all day long and the collectors to but not a complete done set.
Old Nov 11, 2014 | 08:26 AM
Noah Burns's Avatar
if you dyno'd the engine with fender well headers on it… why didn't you keep that pair on the truck?
I really fail to believe conventional long tubes make less power than hacked up junk...
Old Nov 11, 2014 | 08:33 AM
Brian_17's Avatar
Because the bends on the tubes do not fit over the frame and down. It has to have the right bends to clear everything.
And you are entitled to you opinion about hacked up junk. But there is a lot of money and time spent on this truck. I do my research and dyno the engine with different combinations of parts to get the most I can out of my stuff. Just because someone wants to build something who are you to judge? If they are built properly with the correct bends and tube lengths they will not only look good but they will work better too.
Old Nov 11, 2014 | 08:35 AM
Brian_17's Avatar
Rollin Coal Photos by Frank Scott | 2014 Grange Fair Truck Pull (Friday) | Photo 1
