Fast LSXR-T 102mm vs Holley Hi-ram
Old 02-05-2019, 08:03 AM
Pimpinpete's Avatar
Default Fast LSXR-T 102mm vs Holley Hi-ram
Upgrading intakes soon, curious as to which would be better for my application. Stroker Ls1, ported and milled 243s, 238/246 112lsa. NA build for now, procharger in later future. I've heard the Holley will give a tad more power on the top end, while the fast has steady power and torque all over. Opinions? Test results? I have searched but haven't found much.
Old 02-05-2019, 10:28 AM
Jeff71's Avatar
https://www.hotrod.com/articles/20-l...ifolds-tested/
Old 02-05-2019, 12:09 PM
madmann26's Avatar
Short version, neither.
Get a NNBS intake and call it a day. For the cost to HP, it can't be beat.
Old 02-05-2019, 12:48 PM
03sierraslt's Avatar
Just be careful with the TBSS style intake and aftermarket fuel rails with boost. They are prone to popping the brass fuel rail inserts out. Which makes a big fuel leak.
Old 02-05-2019, 01:57 PM
00pooterSS's Avatar
You pretty much already know the deal. Broad power go with the fast, more top end go with the Holley.
FAST came out with different length tubes though so you can tune the power range with them if you want adjustability.
It's hard to beat the FAST and the MSD atomic for broad power.
If you want all the power go with Frankenstein, but be ready to be in debt till your dead to afford one.
Old 02-05-2019, 05:15 PM
Pimpinpete's Avatar
Sounds about right. Curious about how guys are doing harness tucking with the fast, the Holley is nice because you can run the harness underneath it. Also the steam tubes eith the fast, how are people running those?
Old 02-07-2019, 07:40 AM
GREENSIERRA's Avatar
I have ran both, the fast had a little more low end which is expected.
the lsxrt was a pain in the *** to seal right tho, never could get it to seal.
put a hi ram on and all my problems went away.
but a nnbs would probably be just fine for you.
LS1DIME
03-10-2014 10:05 PM
skeet
07-22-2013 01:21 PM
skeet
05-09-2013 07:31 PM
Camin00
11
12-10-2012 07:30 PM
SweetS10V8
08-21-2012 02:45 PM
Quick Reply: Fast LSXR-T 102mm vs Holley Hi-ram
