Factory efan operation parameters inside
Old Jul 31, 2005 | 07:12 PM
moregrip's Avatar
what a rush!
Default Factory efan operation parameters inside
found this on another site, good info:
enjoy!
"The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Important: The right and left cooling fan connectors are interchangeable. When servicing the fans be sure that the connectors are plugged into the correct fan.
The PCM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF if the engine coolant temperature at key-off is greater than 101°C (214°F) the low speed fans will run for a minimum of 60 seconds After 60 seconds, if the coolant temperature drops below 101°C (214°F) the fans will shut OFF. The fans will automatically shut OFF after 3 min. regardless of coolant temperature.
The PCM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set.
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed if required. This insures idle stability by preventing the fans from cycling between high and low speed."
Old Jul 31, 2005 | 08:36 PM
therock's Avatar
Default Well Now!
What I would like to know is where to connect a toggle switch to maually run both fans on high. One reason being is I would like to do this between dyno pulls.
Old Sep 22, 2005 | 06:52 PM
moregrip's Avatar
what a rush!
bump! for good info
Old Sep 22, 2005 | 06:57 PM
bluecajun5.3's Avatar
11 Second Truck Club
that's some good stuff right there. kind of complicated for my cajun education, lol
Old Sep 23, 2005 | 04:36 AM
therock's Avatar
Default 05 E-fan Chart Inside.
Old Sep 23, 2005 | 01:56 PM
TigerFan187's Avatar
Im using the harness fron Nelson and to do the manual override I had to tap into blue 42 pin(PCM) wire to switch and back to ground. So Im assuming if you didnt use a fan harness you could do the same thing and it would work!
Old Sep 23, 2005 | 03:46 PM
CHarris's Avatar
If you have HPT and the laptop with you at the dyno (or the dragstrip) you can command the fans on with the scanner software. That is what I used to do. It worked pretty well, too.
Porscharu914
14
Jan 20, 2016 10:45 AM
carid
Oct 28, 2015 08:24 AM
OHsixLS3
Sep 25, 2015 11:20 AM
chevstang421
Sep 10, 2015 09:16 AM
97gmc
22
Sep 8, 2015 10:56 PM
