Exshaust cut out question
Old Aug 11, 2006 | 07:52 PM
MorepowerTY's Avatar
Default Exshaust cut out question
Can you do an exshaust cut out on a single exshaust?
Old Aug 11, 2006 | 08:07 PM
haole_boySS's Avatar
Of course you can. Install the cut out between the muffler and the Y on the intermediate pipe.
Old Aug 12, 2006 | 07:36 AM
Ok, just asking. I don't know that much, when it comes to this stuff. Can I do this myself, or should I have a shop weld it in?
Old Aug 12, 2006 | 07:52 AM
if you have a welder and means to cut pipe you can otherwise you cant do it yourself
Old Aug 14, 2006 | 09:47 AM
BigRed53's Avatar
all an exhaust cutout does is alow the flow of ur exhaust to drop before your muffler, nothing more, gets loud!
i would suggest if you dont know much about this mod, let an exhaust shop do it, supply the cutout, and it should be relatively cheap (depends on who you know or where u go)
the will just cut a section out of your pipe, and weld the cutout in, u can have manual, or they have electric cutouts,
the manual typically has three wing nuts that hold the plate on, so u can inbolt it and re cap it whenever u want, just gotta get under the truck
or the electrical cutouts have a flap on a motor, that gives u a IN cab switch, to open or close it at your will, SLIGHT leak in the cutout, and i have heard of them going out, but i have them, still work great, cant tell theres a slight leak, and its a good convienience. and im opening and closing them alot.
depends on what u want, and what u wanna pay.
jared
Old Aug 15, 2006 | 06:50 PM
Can you open them half way?
Old Aug 15, 2006 | 07:37 PM
Cuerva's Avatar
11 Second Truck Club
Yes, but I wouldn't do it. The flapper will loosen up that way and will start leaking when closed from too much play.
Old Aug 15, 2006 | 08:16 PM
I did the cutout on my Camaro on the I-pipe between the Y-pipe and muffler and it's definately loud. Get's a little droney on the highway, but sounds amazing when you get on it or at idle. I'd recommend one before any aftermarket $400+ cat-back. Cost me $20 for the cutout (used) and $45 to get it welded on and took all of 30 minutes. Best part is when you cap it up (manual one in my case) it's back to stock, then open it up for car-alarm destroying fun
Old Aug 15, 2006 | 09:25 PM
i agree, i think a cutout would be much more economical when you are deciding whether or not to spend dough on borla exhuast and all the piping, just dump it out and forget the muffler. if you can fit under the truck though, IMO get a manual because in the end youll save hassle (if your elec motor goes out) and you'd save about 180$ right off the bat
Old Aug 15, 2006 | 09:30 PM
RabidStreetRacer's Avatar
I just did a cut out on my stock single pipe exhaust, all you need is a welder, a marker and a Sawzall. It took like 1 min to cut the pipe, then have fun welding it in. I placed mine about 1 foot in front of the stock muffler at the straight pipe. I love it bacuase i can have it completly stock and quite for the long trips, and load and obnoxious when i want it to be. I did a manual cut out from Jegs, and i will probably be ordering I believe a DHM electric cut out attachment for it soon.
