Exhaust upgrade from stock
Old May 16, 2010 | 07:05 PM
tsduke03's Avatar
Default Exhaust upgrade from stock
What options do I have for a upgrade from stock muffler to add a little flow, but not get too loud? I do realized that increased flow will make it louder, but I don't want something that rattles the cab.
Thanks!
Old May 16, 2010 | 07:13 PM
Dewey's Avatar
i've heard good things about the hooker aerochamber, borla, magnaflow, and especially corsa. there's also dynamat to keep down reverb inside the cab. i'm going to dynamat my entire truck over the summer.
Old May 16, 2010 | 07:15 PM
tsduke03's Avatar
Probably should have mentioned I have the 5.3.
Old May 16, 2010 | 07:19 PM
Dewey's Avatar
it really doesn't make a difference. if you're going with the stock y-pipe, you want a 2.5" SI/SO muffler
Old May 16, 2010 | 08:01 PM
08k1500_3's Avatar
I have the Dynomax ultra flow welded muffler on my 08 5.3 for about 3 months now
Sounds good but it is def getting louder as I drive it more.
The crappy part is that the stock muffler goes in 3in and out like 2 3/4 so you will need adapters
Old May 16, 2010 | 08:11 PM
SlvySS's Avatar
22" magnaflow tru x is a bit louder then stock while cruising, has a nice sound when you step on it and has minimum drone.
Old May 16, 2010 | 10:25 PM
Silverdoman's Avatar
I put on the Hooker Aerochamber and love it. Has some noise in the cab when you accelerate but levels out nice and quite. Can bearly hear it a highway speeds. I used the 3" i/o.
Old May 16, 2010 | 11:02 PM
budhayes3's Avatar
PT's Slowest Truck
Pretty sure that the stock piping is 2.75, so he'd be better off with a 3" in/out muffler instead of choking it down to 2.5
Old May 16, 2010 | 11:06 PM
00ChevyScott's Avatar
Wearin' da big hat
You're correct.
Old May 17, 2010 | 12:13 AM
03chevyroyce's Avatar
hooker aerochamber. i absolutely love mine, and it wont break the bank
