exhaust leak cause a sputter??
Old Jan 14, 2009 | 10:35 PM
ZQ8Dude's Avatar
Default exhaust leak cause a sputter??
Hello, my truck has been driving fine, and then i went to an oil change shop. After they changed my oil the truck developed a small sputter. It never did this before and when i had them inspect the truck they discovered a large exhaust leak where my manifold connects to my exhaust piping.
The sputter only lasts for a few seconds after a start up, and then the computer seems to adjust and it runs fine without any sputter.
So could this leak be my problem? Or did the lube shop **** up my truck?
Serves me right for not doing my own work.
Old Jan 15, 2009 | 10:06 AM
MikeGyver's Avatar
It might be, the oxygen sensors might be seeing air that gets sucked into the leak, you need to fix it anyway.
Probably, but they might have only stripped your drain plug.
Old Jan 15, 2009 | 07:01 PM
ZQ8Dude's Avatar
Originally Posted by MikeGyver
It might be, the oxygen sensors might be seeing air that gets sucked into the leak, you need to fix it anyway. Probably, but they might have only stripped your drain plug.
Well i'll find out next time i have to give my truck an oil change.
Anyhow, thanks for the heads up. Tomorrow i'm gonna get under the truck and try to fix the exhaust leak. Worse comes to worse i'll have a local shop fix it w/ a much needed new muffler.
Dan Neumann
11
Aug 7, 2022 09:06 AM
Zacholcomb
Sep 3, 2015 06:14 PM
JFortner5
Aug 20, 2015 06:13 PM
Jake99
Aug 8, 2015 07:56 AM
Ketis
Jul 23, 2015 12:37 PM
