exhaust help
Old Dec 11, 2006 | 06:40 PM
nojpsht04rst's Avatar
Default exhaust help
The shop that the dealer had fix my exhaust when i blew the driveshaft cut the flange off the factory y-pipe and welded the new intermediate pipe to the y-pipe. Now the muffler broke where the front pipe connects to it. So I'm thinkin of either gettin a new y-pipe from Chevy($484+ $50 core) and fixin the muffler or gettin longtubes and fixing the exhaust. So which would be smarter.
1. new factory y-pipe and fix the muffler (around $750)
2. pacesetter L/Ts and ORY and fix the muffler (around $750)
3. dynatech L/Ts and y-pipe and fix the exhaust (around $1500)
Old Dec 11, 2006 | 07:11 PM
Leroy_454's Avatar
Of the choices you listed, I would just go with the pacesetters and put a 3" single exhaust afterwards. You can buy certain cat-backs pretty cheap. Another option would be to cut your stock
Y-pipe off. (leave the pipe from the manifolds back to where the factory Y merges)
You could then have a true dual setup with 2.5" piping. Just run 2 pipes back to a muffler of your choice. (dual inlet/dual outlet, or dual inlet/single outlet) I recommend magnaflow with the true X core. The latter choice would save some cash, but just find a shop who does good work.
Old Dec 12, 2006 | 04:54 PM
I have a RST,so it has an after-cat system on there now and i like the way it sounds so im just orderin a new muffler and intermediate pipe from Regency. But i want to see if its worth while to upgrade to L/T
flatblack83
Jan 3, 2026 07:10 PM
kha4079
Oct 29, 2018 04:38 PM
blown02408
Feb 24, 2016 04:50 AM
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
