is this exhaust enough?
Old 10-14-2011, 11:56 PM
z71vortec's Avatar
Default is this exhaust enough?
i currently have a set of lpp longtubes with 3 inch ORY into a 3 inch single exhaust and out through a borla xr1... is this enough flow to support a maggie supercharger, cam, and overall goal of about 500+ horse? or do i need to go true dual? or upgrade to 4 inch?
Old 10-15-2011, 12:23 AM
gamble686's Avatar
You will begin to benefit from a more free flowing exhaust around that kind of power. The headers are fine as is, but a single 3.5"-4" or true dual 2 3/4" depending on your muffler would be a good choice. Single 3" is good to about 400 from my understanding beyond that it starts to restrict some.
Old 10-15-2011, 06:20 AM
06Sierra2's Avatar
Im wondering the same thing. ive read about 3in-400hp before too. im wondering how much just adding a cutout helps with flow?
Old 10-15-2011, 07:41 AM
z71vortec's Avatar
ok if i have to go true dual then ill be done with it and go true dual 3 inch with 2 borla proxs and an x pipe before them... so i ask... is there anywhere i can just pick up the rear tailpipes? everyone around here wants to rake my body over hot coals and sell my daughter to do a true dual setup in stainless... so i figure im a welder and fabricator... this is cake... however i cant bend pipes and dont feel like dickin around with u bends for 45 million weld joints... so can i just pick up some prebent tails from anywhere? its for an 05 avalanche.
Old 10-15-2011, 12:58 PM
PT's Slowest Truck
budhayes3's Avatar
Is that 400 at the flywheel or rear wheels?
I'm wondering the same thing, as my exhaust is pretty much perfect for my current setup (mild 5.3, StainlessWorks LT's w/ 1 3/4" primaries, 2.5" collectors, and 2.5" to 3" y-pipe, with a 3" cutout after the y, and 3" I/O 18" Magnaflow, dumped after the axle), but I fear that it will choke my LQ9 which I'm planning to have about 475-500 crank hp (if I can ever afford to build it). I'm kinda crossing my fingers that the cutout will be helpful in this situation...
Old 10-15-2011, 09:32 PM
terravast4's Avatar
you can buy some pre-bent pipes from jegs....i bought a kit and handed it over to my welder.
Old 10-15-2011, 10:04 PM
mhotrodscooter's Avatar
I've got dual 3" single DI/DO magnaflow, and it was still holding me back 1mph & tenth or so. Not really sure cuz it wouldn't hook after that.
I think cam design plays a big role in exhaust setups
Old 10-16-2011, 12:39 AM
06Sierra2's Avatar
yeah im sure cam design def plays a big role. i guess if swapping in a bigger motor the best route is to get a custom spec'd cam heavier on the exhaust side of course
Old 10-16-2011, 04:48 AM
11 sec. Truck Mod
TIM Z's Avatar
Yes, your exhaust will support over 500.
I dynoed with ebay stainless headers/ORY , 3'' into a shitty SI DO summit 3'' muffler and made 562 rwhp on a 90* day.
On the way home from the dyno i blew the back out of the muffler, so i put a maganaflow 3'' SI DO muffler on and i could feel the difference, wish i had it on the dyno pulls.
Was my setup optimal ? prob not, but it did support over 500 like you want to do.
Old 10-16-2011, 12:12 PM
ltr450ryder's Avatar
ya im wondering this to witht he 383 im building have lots of cr and a custom cam etc and didnt know if i should still with my 3in si/do or just do dual 3in and whatever mufflers but ya tim if u put the down i mit stay with the 3in si/do
Quick Reply: is this exhaust enough?
