Everybody Needs Nitrous
the reason i prefer nitrous over a supercharger is because it is cheaper and only use it when you need it. not like a charger with constant boost at part throttle.you can spray 150 wet shot pretty safely on LS1 motors, only probably is with the tranny going out fast.
Gray...I completely agree with what you put...I had almost stock 5.3 with a bigger shot thatn you and it ran like a scalled ape. I'm sure it was a mid to low 12 truck....I raced some of the the others from this board, camaro's and mustangs and they could not believe it...Them on tires myself on tires...lol it was so funny, these cars ran from 11.60's to 12.00 on tires and i hole shotted them and didn't get passed till over 85 mph...lol
hey hyde, u gonna put the spray on this motor too??
maybe just a little bit more conservative of a shot this time <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Well actually I'm building my other car again, and it will see a big shot via direct port and a second stage plate system, I'm thinking it will see around 200 from the direct port and another 100 from the plate if needed...The size is not what killed it...it was spraying it from a dig on tires with no converter....But it rolled out....lol
i think you are just filled with envy because this guy gets more women than you . or maybe it is because the only females you can pick up are the ones at the play ground you stake out with your unmarked van
<small>[ September 03, 2002, 12:29 PM: Message edited by: RED2K ]</small>
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
