EVAP System code P0440.
Old Nov 7, 2010 | 11:28 AM
Mrgoodwrench3's Avatar
The PCM will only run the EVAP test when the fuel level is between 1/4 and 3/4. If you have checked the cap and the light comes back on several time you probably have a leak somewhere. These can be hard to find. A professional shop will have a smoke machine to help in the diagnosis. There is a small plastic line from the fuel tank to the intake manifold. Near the manifold it has a service port with a Green cap. Make sure this is not loose. Check all other hoses under the hood.
Old Nov 7, 2010 | 11:35 AM
fastnblu's Avatar
Originally Posted by Tom@SpeedInc
P0440 is evap malfunction, if your gas cap wasn't tight to the point of clicking (3 clicks is the torque spec, belive it or not) theirs a good chance that was the cause. If the fuel has been overfilled, it can be sucked into the charcoal canister causing P0440 but most the time any serious malfuntion of canister, vacuum leak, VSV etc will cause P0440 P0441 P0446 to all be shown.
I just learned that overfilling can be an issue , but I'm thinkin / wondering if I tweaked it when I swapped tranny in.
Where is the evap vent solenoid located on my '04? I have yet to fix mine, but fillups suck beyond belief, they take forever & it's gettin cold here now.
I was gonna ask too, how much does a dlr. charge for that smoke test?
Old Nov 7, 2010 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
We charge 1.0 labor to start for an EVAP diagnosis...
Small leaks can be hard to find, all it takes is a pin hole. If anything has been tampered with (ie, fuel pump been replaced), I'd check there first. Guys have used soapy water and very light pressurized air to find leaks, but this can be tough to do, as a lot of folks use too much pressure and end up pinning the pressure sensor. You don't want to use shop air turned all of the way up, or you will definitely be replacing more EVAP parts.
Old Nov 7, 2010 | 04:05 PM
kvpaintbal's Avatar
My light is on too cause of that from the shop here. Where I'm from. Said its a vent hose that gets full of dirt. Is there. A way to take it off by doing a tune
Old Nov 7, 2010 | 04:11 PM
fastnblu's Avatar
A tune will not remove it. When my tuner did tune for cam, he got rid of all the codes. That 1 came back.
Old Nov 7, 2010 | 06:16 PM
chevy1500's Avatar
Registered User
i got code p0440 and replaced the gas cap, cleaned the tank vent solenoid,purge valve and hooked them up to 12v power and they click when supplied power. i have heard that if you over fill your tank that could cause the canister to go bad. i always put as much gas as possible in my truck so could that be my problem? it seems like the light comes on right when my truck reaches 3/4 of a tank. i took the canister off and no fuel came out it, sounded like sand was inside, is that normal? im kinda leaning toward the canister being bad. what do yal think?
Old Nov 7, 2010 | 07:14 PM
Component Location
Evaporative Emission Canister Purge Solenoid On the top right rear of the engine
Customer Concern:
Powertrain Control Module (PCM) code P0440 sets.
Tests/Procedures:
1. Check for dirt in the evaporative hose, evaporative canister, evaporative vent solenoid.
2. Check for obvious signs of leakage in the evaporative hoses, fuel tank filler, fuel cap, etc.
3. Check for leaking Purge Solenoid.
4. Check Fuel Tank Pressure (FTP) sensor grommet.
5. Check fuel level sender O ring.
Potential Causes:
Fuel Cap
Fuel Sender O-Ring
Purge Solenoid
Vent Control Solenoid
Diagnostic Codes:
P0440
Old Nov 7, 2010 | 10:03 PM
chevy1500's Avatar
Registered User
Default purge solenoid leak?
how do you check for a leaking purge valve? when i took it off it sat in there kinda loose, i think thats just the way it sits in there.
Old Nov 7, 2010 | 10:52 PM
SnakeOiler's Avatar
Get a flashlight and start looking for any type of rodent damage.
I had a P0452 just last week, because something ( I believe it was a squirrel) chewed through two of the three wires at the fuel tank pressure sensor connector.
Old Nov 8, 2010 | 09:22 AM
chevy1500's Avatar
Registered User
ok i took off the canister yesterday looking to see if it was filled with fuel but no fuel came out.i figured that may be that was the problem because i always fill my tank as much as possible. it sounded like sand was in there when i shook it, should there be a sandy substance in there?
