Et gain?
Old Oct 26, 2011 | 06:52 AM
  #21
KLUG'S SS's Avatar
FormerVendor
As mentioned already your compression ratio is now at the very least right at 12:1 assuming the combustion chambers are now right at 58 cc which you had said.
Just a tad bit high for an everyday street machine IMO.
Old Oct 26, 2011 | 08:08 AM
  #22
youngbuck's Avatar
Is there anyway to lower the compression without swapping the heads? What is a safe compression for a dd ? Should I be ok with a 12:1 with a good tune an lower temp thermostat?
Old Oct 26, 2011 | 09:09 AM
  #23
Rhino79's Avatar
9 Second Club
I've seen f bodies run that cr on a good tune, but they are lighter. I'd say 11.5 would be a nice Target. Look at different head gaskets and figure our static and dcr.
Old Oct 26, 2011 | 02:04 PM
  #24
grey matter 04's Avatar
13 Second Truck Club
running a thick head gasket will lower compression some
Old Oct 26, 2011 | 02:28 PM
  #25
youngbuck's Avatar
How thick of one would I need to get into the 11:5 range?
Old Oct 26, 2011 | 03:43 PM
  #26
AndysC3's Avatar
what gaskets do you have on there now?
Old Oct 26, 2011 | 04:32 PM
  #27
youngbuck's Avatar
Just stock replacement.
Old Oct 26, 2011 | 07:19 PM
  #28
AndysC3's Avatar
the stock replacements are .051" compressed thickness. You could get some of these in a .060 to take your compression to about 11.7:1 or .065 which will be about 11.5:1
Cometic Gasket - C5751 - Cometic Head Gasket 4.060" Bore - Speed Engineering Performance Parts
Old Oct 26, 2011 | 10:19 PM
  #29
youngbuck's Avatar
Tht would get me in the sweet spot right?
Old Oct 26, 2011 | 10:24 PM
  #30
AndysC3's Avatar
Have you been driving the truck around? I would do some lite driving and see how it does. But you would really benefit from some more free flowing heads.
