escalade alternator upgrade on 02 silverado
installed a 130 amp alternator on my truck today. it is the alternator that comes on the escalade truck with the 6.0. i also had to get the belt for that same application.
gm part#s 10464453 gen 267.80 12569348 belt 49.64 little expensive but well worth it. will work well when i get my ls1 fans. http://images.cardomain.com/member_i...32_24_full.jpg http://images.cardomain.com/member_i...32_25_full.jpg also installed top post 1000ca battery. :drive: |
Re: escalade alternator upgrade on 02 silverado
Did you do this because you have under drive pulleys? I did not see them in you sig, but just thought I would ask. Also why did you need a different belt, did it have a bigger-smaller pulley on it?
What do we have stock, 105 amp alternators?
we have 105 amp alternators stock. i went to a 130 amp alt since i have a custom high end stereo,85 watt headlight bulbs and 35 amp driving lights and i am planning on ls1 fans. the extra amps are going to be very useful in the very near future. oh you have to use the different belt since the 130 alt is bigger and the belt is a little longer. :drive:
Damn man! You can get a 200A for around $200 for Alterstart@aol.com
