Enter to Win Contest!
#31
Thanks.
#32
Even if the roller on the lifter locked up it shouldn't have damaged the lobes like that so it's definately from a soft cam. I don't think I've ever seen one with wear like that though so that's a decent failure rate. HAHA!
#35
I don't remember, I'll check asap, I think tomorrow.New stock lifters (LS7). I might go a little bigger than the 222-224, .566-.568, 115 lsa that this cam was. It had too much bottom-end power, you know...
#37
There was no chance of warranty because of the age of the cam, but in my dream world they might have done something if it was their fault. Today I found out that Comp said there was nothing wrong with the cam, a hardness test said it was OK. They said the same of their 875 (Pro R) lifters. They suggested that the lifter trays were allowing the lifters to wiggle. I say B. S. I know the trays should have been replaced at the time of the rebuild, but there is no cracks or lifter play. There is nothing wrong with the build specs otherwise, I say there must have been porosity in the cam lobes or lifter rollers. But if there was, it is worn away.
I am not naming Comp as the manufacturer to somehow punish them, I think it is a freak occurrence. I am just letting you know whose cam it was because it is silly not to. I don't think my little problem will affect anybody's opinion of Comp, in fact I am replacing it with another Comp.
This time I am going to take my chances with stock LS7 lifters, The Comp Rs were too noisy. And new lifter trays, of course.
#38
Intresting results... I wonder were the hardness test was done on the cam... I am starting to wonder if the stiffer springs we all have to run with these larger cams are causeing the cams to wear prematurely on start up....
