Engine wont fire please help!
Old Apr 20, 2010 | 11:46 AM
jcfreeman0's Avatar
Originally Posted by 454navyss
so you cleaned the plugs but are they firing?
I checked last night and i'm getting spark. This morning i pulled one plug out and its covered in black crud and wet. I think im gonna get new plugs / try cleaning these to see if it works. I havent cleaned them yet but i did order new plugs. They'll be in tomorrow.
Old Apr 20, 2010 | 12:40 PM
Ferocity02's Avatar
Does the security light flash after trying to start it?
Old Apr 20, 2010 | 12:55 PM
jcfreeman0's Avatar
I do not have a factory cluster. I have a 64 Impala dash in my truck.
I had blackbear tune out the passlock system last year. Before i tore it down again over the winter it would start every time. (I havent done anything different with the engine this time just had to take the cab off to rebuild the firewall)
I do remember before i got it tuned it would run for a second and then die (when the passlock was on) but now it wont even fire at all. Just cranks and maybe once every 15 seconds a brief fire.
Again this is after it was running just the other day for 30 seconds to a minute. Thats why its so confusing to me lol. If it wouldnt have started at all it wouldnt be as frustrating.
Old Apr 20, 2010 | 09:30 PM
jcfreeman0's Avatar
I pulled all the plugs out tonight and cleaned them up a little bit and put them all back in and it "almost" starts. It fires about every other try but wont actually start. I ordered some new NGK's today (wont be in until tomorrow) so hopefully the new plugs will solve my problem.
Old Apr 21, 2010 | 08:16 AM
454navyss's Avatar
i want to see pictures of the 64 Impala dash in your truck, sounds interesting
Old Apr 21, 2010 | 08:24 AM
jcfreeman0's Avatar
Still a work in progress but almost done...
I picked up my plugs this morning. I can't wait to put them in and see it that works!
Heres a few more pics of the truck. I'm trying to get it to Showfest next month.
Old Apr 21, 2010 | 08:26 AM
454navyss's Avatar
is it aftermarket, custom made or straight out of a 64 Impala? it looks good in there
EDIT: you should make a thread in the Project Gallery
Old Apr 21, 2010 | 09:12 AM
jcfreeman0's Avatar
I built the ends / sides out of metal. I shaped them by hand and continued the body line through them to match the rest of the dash. (there were no ends from the impala) I also made them so they fit my stock pillars. On the top side (by the windshield) I had to extend the dash about 4-6" to fit my truck. I also filled in where the stock controls were on the dash because i wanted a clean look. I will probably add some switches right there though.
Old Apr 21, 2010 | 09:41 AM
shandy294's Avatar
Did you try some additive in the gas...Sea Foam,BG-44K,etc. ? If the old gas did break down or was dirty or had water,there might still be remnants of it in your fuel system.
Nice looking truck!
Old Apr 21, 2010 | 10:08 AM
jcfreeman0's Avatar
Nice looking truck!
No i didnt. Should i just add it to the tank? I'll pick some up today. I did add about 3 gallons of new gas to the existing 3 gallons.
Also i just started a project thread if you want to see more pictures / the different stages of my truck.
