Engine swap
Old Aug 7, 2012 | 04:10 PM
tazer1987's Avatar
Registered User
Default Engine swap
Does anyone have a link or a write up on swaping from a 5.3 to a 6.0?
Old Aug 7, 2012 | 04:30 PM
nonnieselman's Avatar
Thats a pretty straight forward swap..
not sure what your looking for
Old Aug 7, 2012 | 04:56 PM
TXSZ66AVLANCHE's Avatar
Write up: remove 5.3, install 6.0
Done
Old Aug 7, 2012 | 04:59 PM
Done
Forgot the tune..
Old Aug 7, 2012 | 10:22 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Replace any respective parts that may visually appear to be different like the fly wheel. The Intake is the same but the fitting on the back may not be the same. It may be plugged if it came from a hydro boost equipped vehicle. Also make sure the sensors are the same. Some changed and the plug that fits it may be different.
Old Aug 7, 2012 | 11:16 PM
J_SIN's Avatar
4.8 to 6.0 Engine Swap
Old Aug 8, 2012 | 06:44 AM
Forgot the tune..
he only asked about the swap itself
Old Aug 8, 2012 | 03:23 PM
tazer1987's Avatar
Registered User
Thanks you guys. I'm not worried about the tune as much as I am about the process.
Old Aug 8, 2012 | 03:25 PM
tazer1987's Avatar
Registered User
I like to plan for as much as I can so there's no surprises.
Old Aug 9, 2012 | 11:17 AM
bgray's Avatar
TOTM: June 2007
no different then if you were replacing your 5.3 with another 5.3. Theres nothing special required, its very straight forward.
Would rec pulling trans with motor, much easier
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
