engine swap
Old Oct 18, 2004 | 11:56 PM
intro5002's Avatar
Default engine swap
I have a 1999 GMC seirra rcsb with a 5.3L. I want to swap for a LQ9 6.0L. I have a budget of 7500 to 8500. I need everything engine, electronics, trans, rear gears/locker, and some performance upgrades. Does anyone have suggestions as far as a parts list. What is the best I can do with my budget? Thanks
Old Oct 19, 2004 | 12:06 AM
GoldenVelvet's Avatar
I see this is your first post. Welcome! Just to warn you, this site is addictive.
Now back to your question; With that much money you can do A LOT. Throw a 6.0 in there with some boost on top of it. Have a motor built. Put in a stock 6.0 with a few bolt-ons. I would recommend reading some of the post here and using the search button to get an idea of what can be done. Also if you dont have a posi track that should be your first mod.
Old Oct 19, 2004 | 01:29 AM
if u have the 5.3 why do u need the electronics and trans???
Old Oct 20, 2004 | 06:50 PM
RICEBURNR's Avatar
All I can say is do alot of research first, Im doing a motor swap myself just not as complicated. Thats a huge budget, so spend wisely, good luck.
Old Oct 20, 2004 | 08:58 PM
slowprocess's Avatar
Just done it, only with the lq4. Use everything off of your 5.3L, unless you can't for some reason. I love it because you can't tell the difference in my 6.0l and my old 4.8L under the hood. It even has 4.8L on the radiator shroud!!!
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
