Engine swap
Old Feb 16, 2004 | 01:22 PM
12sec.5.3's Avatar
Default Engine swap
I currently have a ls1 5.3 in my truck. I was thinking maybe putting everything from it onto a ls1 5.7. The cam will probably be a little small, but I'll upgrade that later. I'll have to get the combustion chambers on the heads cut to fit also, i think.?? My question is would the alternater, power steering pump bracket, A.C., etc... bolt up like it is now or would I have to custom make a bracket? I'm also wondering if the converter would fit or have to change the drive plate? Any info would help!!
Old Feb 16, 2004 | 02:50 PM
Sport Side's Avatar
i always heard it was a direct swap
Old Feb 16, 2004 | 02:58 PM
2003blue5.7's Avatar
Yes if you use all your truck accesories you will have an easy swap. I have been there and done that. PM me if you need further info
Old Feb 16, 2004 | 03:15 PM
Would you have to swap out the PCM or not? And if so how hard will it be to do that?
Old Feb 16, 2004 | 03:18 PM
I am currently running my stick 5.3 pcm and it runs just fine. I know with a tune it will run allot better.
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
