Engine rpm and shift points
Old Jul 19, 2008 | 08:29 PM
southern_chevy's Avatar
Default Engine rpm and shift points
Well I have been trying to get my shift points low enough so they do not hit the limiter but it pulls strong enough up there that it will hit the limiter even tho the limiter is 500rpm higher then the shift points. So how hight can you safely spin a 5.3 with stock bottom end? Also what are yall shifting at with a 220 cam? Mine seems like it wants to keep revving but I do not want it to come apart so the rev limiter is at 6500 now.
Old Jul 19, 2008 | 09:38 PM
ChevyTruck's Avatar
something else
dont know if this will help but i have read on here that the stock crank can take up to 800 hp.
Old Jul 19, 2008 | 09:58 PM
Nope no help but thanks. From what I have heard rpm will kill a motor faster then power will but just what I have heard. I am not sure how far you can push one rpm wise before things start to stretch or come loose.
Old Jul 19, 2008 | 10:06 PM
JennaBear's Avatar
Truck Sponsor
If you have a loose torque converter, you may need more than a 500rpm split on your shift speed versus shift rpm.
BlackGMC's Avatar
Resident Retard
the engine wont have a problem shifting that high, but your tranny will
Old Jul 19, 2008 | 10:23 PM
Stock stall for now, but my tune is set to shift at 6100 and limiter at 6500 and it will bounce of the limiter. That sounds about right about the trans. Do I see lucky number 3 in my future. lol
Old Jul 19, 2008 | 10:35 PM
JennaBear's Avatar
Truck Sponsor
Get a log that has gm.gear as one of the PIDs, and you will be able to tell when you are commanding the shift. If it is commanding well before it occurs then you likely need more line pressure.
Old Jul 19, 2008 | 11:07 PM
BlackGMC's Avatar
Resident Retard
and lower shift times....
Old Jul 19, 2008 | 11:19 PM
v8
17,16,15,14,13,12,11 Drvr
7000 here
Old Jul 19, 2008 | 11:20 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by v8
7000 here
holy crap! I bet that this screams!!
