Engine problem...? Transmission?....u tell me
Old Mar 28, 2006 | 10:58 PM
Fellow294's Avatar
Default Engine problem...? Transmission?....u tell me
Mods in sig, but problem is when running around 75 or 80mph...stand on it so its WOT, the rpm's jump to 5000 and run up to 6100, and it shifts. well at this point I am right around 100mph, but when it shifts, it drops to around 36 or 3700rpm's and it takes it FOREVER! to get on down and around to 120mph...? what is causing this and is there anything that can be done about it relatively cheap....? Thanks in advance!
Old Mar 29, 2006 | 06:34 AM
912jonathon's Avatar
it is normal on these trucks. if you want more topend, put a cam in it
Old Mar 29, 2006 | 09:20 AM
The shorties don't help much and the superchips should be replaced with a custom tune to take full advantage of your engine throughout the rpm range. I noticed a huge difference when I changed from a handheld tuner to a custom tune. I got more power everywhere. Topend was perfect. I also noticed the SOTP difference when changing from Flowmaster to Magnaflow. And the drone at highway speeds was gone which is what I wanted in the first place. I was like alot of newbie's I bought a handheld tuner, Granatelli mass air , throttle body spacer, shortie headers, these things did not do much for performance and now I know better NOT to spend my money on crappy products. My 0.02
Old Mar 29, 2006 | 10:26 AM
$thatguy$'s Avatar
Old Mar 29, 2006 | 10:43 AM
LS1TRUCKGUY's Avatar
HANDHELDS & SHORTIES LONGTUBES & CUSTOM TUNE
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
5.3Okasai
Mar 9, 2022 01:07 PM
ROB 1 TON
Jul 13, 2015 04:43 PM
Mark_k
Jul 9, 2015 12:37 AM
Nimoryan
Jul 5, 2015 03:50 PM
