Engine build up questions
Old Sep 23, 2009 | 03:43 PM
lowchevytrucks8503's Avatar
Default Engine build up questions
I am building a '85 C10. I am planning on a 6.0/4l80 swap. I want some opinions on a stall and cam. I dont have any goals but I'd be pretty happy with somewhere in the 450 range on the motor or more. I'm still going to have a/c and cruise control. I'm building the truck to be a really fast driver and still reliable. I'm doing the swap because I'm tired of messing with the carbed 305. I also plan to stay NA. I would also like to get a 9.5 rear end outta 454SS/ anyone know if they made any with disc brakes? Any opinions would be greatly appreciated. thanks guys
Old Sep 23, 2009 | 05:08 PM
I was thinking 3000 stall, 3.73 gears with tru trac, and maybe a G5X3 cam?
Old Sep 23, 2009 | 05:14 PM
GMCtrk's Avatar
the 305 isnt making power?
Old Sep 23, 2009 | 05:20 PM
lol. any advice? I have no idea what springs or anything would be best.....
Old Sep 23, 2009 | 05:23 PM
GMCtrk's Avatar
the most common combos are usually 3200 to 3600 stall and 220-230 duration cam.
Old Sep 23, 2009 | 05:25 PM
Okay anything else I should do the the motor. I'm not sure yet if I'll end up with a lq4 or a lq9. The have the same heads right?
Old Sep 23, 2009 | 05:28 PM
GMCtrk's Avatar
yes. Did you consider a big block?
Old Sep 23, 2009 | 05:30 PM
No I guess I never have considered a bigblock. I dont know if I can get what I want outta one.
Old Sep 23, 2009 | 05:33 PM
budhayes3's Avatar
PT's Slowest Truck
Same heads, as far as what else to do it depends on how high you want to spin the motor, a lot of guys like to replace the rod bolts with ARP's, and I've heard that the Katech rod bolts are good too.
Old Sep 23, 2009 | 05:35 PM
okay thanks, i'm thinking the G5X3 is too big of a cam.
