electric throttle body
Old Oct 7, 2003 | 11:40 AM
Tokez420's Avatar
Default electric throttle body
can any post any info on them. i would just like to learn more on them. in pros or cons.
Old Oct 7, 2003 | 11:50 AM
DemonSilverado's Avatar
Default Re: electric throttle body
Are you talking about the drive by wire TB's on the 03's and up??
If so I have one (since I have an 03) and I have yet to locate a replacement part should I want to go bigger, nor have I been able to detirmine if the blade opens to a 90 or not. If not I doubt there is a way to fix it....
In other words, I dont know anything. But from looking at mine it appears to be a solid design.
Old Oct 7, 2003 | 01:29 PM
My 01 uses a 6 wire dual TPS at the throttlebody and a third TPS on the accelarator peddle hooked to a small computer on the drivers side corner of the firewall that has a 2 wire hookup to signal to a motor on the side of the throttlebody.Installing one would be easy you just need all the components.
Old Oct 9, 2003 | 01:18 AM
Yes, our throttle bodies open a full 90 degrees on the drive by wire, and it is not to hard to polish the TB for better performance.
Old Oct 9, 2003 | 08:42 AM
2003blue5.7's Avatar
I had a stock 03 throttle body opened up to 78 mm and Im getting a decreased engine power message.. anyone know how to fix that?
jdb11386
Dec 3, 2015 09:34 PM
SlicksNchicks
Aug 31, 2015 10:56 PM
smokeshow
Aug 23, 2015 08:23 PM
noproblems209
Aug 10, 2015 06:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
