electric fans?
Old Apr 4, 2007 | 12:14 AM
OrlandoFL4.8's Avatar
Default electric fans?
I came across some electric fans and they are advertised as:
Dual fan setup for 98-02 LS1 Camaros and Firebirds, measurements are 28"x18"x6", and the picks of them are below.
Are these the fans that most of you are swapping to, and do these look like they would work with my truck in signature? I know that I should also get a nelson harness, and will need some computer tuning to get them to work, but other than that, should I be OK?
Thanks in advance
Old Apr 4, 2007 | 12:20 AM
Lurius's Avatar
Those are the ls1 fans everyone uses. When you put in that lq9 did you put in a 34" radiator? If you have the 27" radiator that should work fine and fit it like a glove.. Otherwise I am unsure of the fitment. As for having it wired up, look into a nelson performance electric fan harness. I bought one off a member here recently and it worked like a charm!
-Lurius
Old Apr 4, 2007 | 12:25 AM
RoosterMcCandles's Avatar
It doesn't matter which radiator you have, they will work. You may have to fab up some brackets but that shouldn't be too hard...
Old Apr 4, 2007 | 12:27 AM
-Lurius
I still have the original radiator that came with 4.8 so it should be the 27". Should I also be concerned if it comes with the stock wiring harness of some sort that can plug into the nelson harness or does the nelson harness pretty much take care of everything? Thanks so far and srry for all the questions
Old Apr 4, 2007 | 12:30 AM
Thanks, I have also seen some of the brackets that are being fabbed up to keep them snug up top, I even seen some use zip ties Well its gettin late, I will check back tomorrow, work is gonna come early
Old Apr 4, 2007 | 07:21 AM
Lord Aries's Avatar
I've got those on my 34inch radiator and they work great! very easy to install and fab up the brackets... E-Fans for under $200 + HP Gains = w00t!
Old Apr 4, 2007 | 06:59 PM
speedy02's Avatar
same ones i use!
Old Apr 4, 2007 | 08:07 PM
sbw9056's Avatar
I use the same fans with a Flexalite VSC. Works great, and you don't have to run it through the computer.
Old Apr 4, 2007 | 08:13 PM
truckmann's Avatar
PM DLH2006 he is making harnesses. I'm sure the nelson harnesses are great, but they are overpriced IMO.
Old Apr 4, 2007 | 10:43 PM
Thanks I will check all options and appreciate the info .
