Electric fan question
Old Feb 17, 2010 | 10:46 PM
BigHate's Avatar
Default Electric fan question
i have a 00' silverado w/the fan clutch. if i have a electric fan assembly out of an 05'-07' truck will it bolt directly like the shroud does or will i have to fabricate brackets? also are the fan harnesses nelson performance sells the best way to go wiring it? gettin tired of the tornado sound!
Old Feb 17, 2010 | 10:49 PM
Atomic's Avatar
I have a gauge for that
No.
You have the 28" rad, you need the 34"
Old Feb 17, 2010 | 11:33 PM
BigHate's Avatar
so 292 flex-a-lite fan kit that fits the 28" radiators a good bet?
Old Feb 17, 2010 | 11:36 PM
GMCtrk's Avatar
The LS1 fans are OEM and are better (found on 98-02 camaro, trans am). They fit perfect and work great with the nelson or blackbear harness.
Old Feb 17, 2010 | 11:51 PM
BigHate's Avatar
wurd! thanks guys
Old Feb 18, 2010 | 12:09 AM
Atomic's Avatar
IMO, if you already have the 05-07 fans, it would be much easier and better overall to just get the larger rad. It will be a direct replacement, and have better cooling ability.
Old Feb 18, 2010 | 01:10 AM
budhayes3's Avatar
PT's Slowest Truck
Swapping in a 34" rad is no big deal, it's a direct swap and all you'll need is 2 more bolts like the ones that are already holding the current rad in, so you can secure the 05+ efans to the radiator support. I got my radiator brand new from radiatorbarn.com about 5ish years ago, and found out from a buddy here that their 34" rads are actually now about $100 cheaper than when I bought mine. Search threads started by "fastnblu", he has an excellent 05 efan write up There might even still be a link to the thread in his sig
Bluchevypick
Aug 18, 2015 09:11 AM
razorshot
Aug 10, 2015 08:10 PM
Ketis
Jul 23, 2015 12:37 PM
