Electric fan install
Old Aug 28, 2003 | 10:58 PM
JeremyF's Avatar
LS1TECH Sponsor
Default Electric fan install
anyone have any details on this one? 01-02 PCM. I know it is possible to get a signal from the PCM to enable the fans given the command, like a vette or camaro. What is the location? and what are the gains in HP? 10RWHP on a 5.3? Does the camaro fan setup work? What are you guys using for fans?
Jeremy Formato
Old Aug 29, 2003 | 01:55 AM
Flyer's Avatar
Default Re: Electric fan install
Most use the Flex-a-Lite 282's. The problem with this is you have to have the bigger radiator.
I think the Camaro fans will fit on the smaller radiator, but I'm not sure.
I read somewhere that you can tap intthe PCM and use a relay to turn the fans on and off using the PCM, but I don't remember what number pin it was. Try looking around a little bit and see if you can find it.
I just put my fans on mine tonite, along with the bigger radiator. I like the sound of them MUCH better than the stocker. I'm not sure of any gains though.
Old Aug 31, 2003 | 01:10 PM
FILE's Avatar
Jeremy Formato
http://www.ls1truck.com/reference/ar...ng_frames.html
there you go. hope this helps
mr03silverado
Aug 13, 2015 11:40 AM
razorshot
Aug 10, 2015 08:10 PM
Ketis
Jul 23, 2015 12:37 PM
