electric fan
Old Aug 28, 2007 | 09:34 AM
JHALL7644's Avatar
Unhappy electric fan
what kind of fan should i go with on my 2004 4.8 motor
Old Aug 28, 2007 | 10:57 AM
Beastofa327's Avatar
Pick up a ls1/lt1 fan from ebay. Price between 75-100 $
Old Aug 28, 2007 | 11:36 AM
Derek @ EDO's Avatar
FormerVendor
btw i have a harness made for the ls1 fans ready to be shipped.
Old Aug 28, 2007 | 12:07 PM
jons03's Avatar
What's involved with the harness? Is it just a plug and play deal? Or do you need a tune for the PCM to operate?
Old Aug 28, 2007 | 03:49 PM
JHALL7644's Avatar
would that be a dual fan or a single fan
Old Aug 28, 2007 | 05:39 PM
dual fan
Old Aug 28, 2007 | 06:30 PM
Z28RPM's Avatar
11 Second Club
Pin 42 blue connector on PCM will run fan. It is ground based and needs a relay to run fan. Then it hasto be programmed to turn fan on ant temp desired.
Old Aug 28, 2007 | 07:56 PM
FormerVendor
pin 42 needs to be tuned, other than that its plug and play.
Old Aug 28, 2007 | 09:04 PM
Wide Open's Avatar
Where are you guys getting the relays to turn on the fans? Is there a specific type to use? I have the flex-a-lite fans and would like to get rid of their vcm and have the ECM control both fans.
Old Aug 29, 2007 | 09:44 AM
PM DLH2006, he'll make one for you and send it out right away
