EGR removal, blockoff question?
Old Jul 25, 2005 | 09:12 PM
ReedyCreekRacin's Avatar
Default EGR removal, blockoff question?
what have you fellas used to block off the EGR port on the intake manifold when you remove the EGR system?
the headers came w/ a plate to block off the tube at the #2 primary, but im wondering about the other end at the manifold. thanks, CHIP
Old Jul 25, 2005 | 09:19 PM
You can use a rubber freeze plug, but I cant remember the size. I'm sure someone will chime in.
Old Jul 25, 2005 | 09:28 PM
budhayes3's Avatar
PT's Slowest Truck
I got an egr delete plug at the dealer, think it was about $15...Thunder racing sells them also I think. I'll see if I can dig up the part #'s...
Old Jul 25, 2005 | 09:35 PM
budhayes3's Avatar
PT's Slowest Truck
I think this is the part# for the manifold plug: 12558346 $17.10 (got a discount...lists for about $24)
I got the EGR block off and gasket for the headers from Thunder Racing
EGR Stainless Steel Block Off Plate: 99-86EGR $10
GM LS1 EGR Valve Gasket: 20-1255304 $6.09
Old Jul 25, 2005 | 09:40 PM
Z284thgen's Avatar
11 Second Club
i think the plug size is 1 1/4
Old Jul 25, 2005 | 09:41 PM
cool, thanks man. ill stop by the dealership on my lunchbreak tomorrow and see whats up. so its just a plug, dont need another gasket for the manifold?
ive already got the blockoff plate and gasket for the header. CHIP
Old Jul 25, 2005 | 09:55 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, when you unbolt the egr pipe from the manifold, you use the same bolt to hold the plug in...it's a little metal plate with a sort of o-ring on it, if I remember correctly.
Old Jul 25, 2005 | 11:25 PM
white1's Avatar
I'm cheap, I used a piece of gasket material, and gasket maker (silicone). Total cost $0.00
Old Jul 26, 2005 | 07:44 PM
Budhayes3....the part number you gave me was right. ordered it from the dealer today, $12 and change.
white1...i thought about making a piece, but i'd rather have something i wont have to worry about leaking. dont want to be bothered w/ a vaccum leak.
thanks fellas, CHIP
Old Jul 27, 2005 | 07:09 PM
greentahoe's Avatar
Was there anything that you guys did as far as tuning?? Why did you choose to do this? I ask b/c I think I may need all the room I can get in the engine bay
