egr block off. couple questions.
Old Jul 26, 2009 | 03:35 PM
bubbakutz's Avatar
Default egr block off. couple questions.
my lpp headers that are going on in a few weeks don't run egr. so i had a few questions about removing it/blocking it off. instead of just buying a plug, i'm going to buy the block off plate from gm but i'm not sure which one it is. it blocks it off at the intake manifold right? is it part number 12558346 or 12554606? also, i don't know what it's called but do you guys remove the part that is in between the manifold and intake manifold or leave it there and just remove the tubes? if you remove it, what do you do about the wiring going to it? here's what i'm taking about incase you didn't know by my description. thanks.
Old Jul 26, 2009 | 04:43 PM
neilownz's Avatar
I unplugged, zip tied that to the fuel rail, and unbolted it from the head, but it threw a couple codes that I had to change.
Old Jul 26, 2009 | 08:28 PM
bubbakutz's Avatar
ok cool. i'm not worrying about codes. i'm getting a bb tune next month so that should clear it.
Old Jul 26, 2009 | 09:26 PM
neilownz's Avatar
Some people use that egr plug to power or get info from a wideband o2 sensor I think. Not sure on the particulars with that setup. Better to keep it around at least. Did you find the part # by searching a little? I think it's 12558346
jfuegner
Dec 22, 2016 03:47 PM
Noah Burns
Sep 7, 2015 05:50 PM
Fast86z
Aug 23, 2015 12:35 AM
GreyChevy
Jul 7, 2015 08:57 PM
