eBay head studs
Old 08-20-2012, 12:26 AM
  #21
midevil1's Avatar
Originally Posted by iregret
You don't have to pull the engine to remove the heads when studs are installed? Really?
I've never installed head studs before but just looking at my truck, it doesn't look like there's room. Are you suggesting removing the studs as well? Like remove all the nuts from the studs, then remove the studs and then pull the heads?
I'll be doing this to my LQ4 and it's on an engine stand, so there's no problem with installing head studs for me. (obviously) I didn't think you could install them with the engine still in the truck.
You'd have to remove the studs too in an F-body. If you can't get the heads off in the truck without removing studs, something is wrong.
Old 08-20-2012, 12:56 AM
  #22
Charlie Murphy!
iregret's Avatar
Huh. It just looked like the brake booster is in the way.
I've been researching lube for the head stud install. I found this in ARP's website:
ARP-bolts.com | Answers to Frequently Asked Questions
It says in there that you can use loc-tite instead of lube. I don't have a speed shop near by so I'd have to order what ever lube I'd use. I've got a napa and autozone near me. The workers there are pretty clueless so unless I know exactly what lube I need, I'll have to order it or use red loc-tite.
Any recommendations on what lube to use on head studs? I've read some folks just use oil.
Old 08-20-2012, 01:25 AM
  #23
Baltimore Whore
Mangled03gmc's Avatar
As for the lube, you can use motor oil( yah I know there are some arguments ) I have used it on all my engines, as has my father with never a issue( 1xx engines)
  #24
Charlie Murphy!
iregret's Avatar
I found the instructions on ARP's website.
http://arpinstructions.com/instructions/234-4316.pdf
In the second half they recommend a 25ftlb torque. They must be talking about the smaller studs.
Here's the proper lube.
ARP Ultra Torque Assembly Lubricant
Old 08-20-2012, 06:12 AM
  #25
Charlie Murphy!
iregret's Avatar
Are you saying you've used motor oil instead of lube on over 100 different engines?
Old 08-20-2012, 07:55 AM
  #26
03regcab sierra's Avatar
I have 3k miles on my ls1 using those head studs and my brother has about the the same on his blown lq4 so far no issues. I have 2 more sets laying at my shop for future builds already since they are so cheap
Old 08-20-2012, 09:09 AM
  #27
Baltimore Whore
Yes. Like I said i am sure the die hards will say no you cant do that, but if you do the sequence, let sit for a little and go back over them, it works no problem.
Old 08-20-2012, 09:15 AM
  #28
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
ARP's instructions even given separate tq specs for using oil. Done it plenty of times, usually an extra 10ftlbs over using the moly lube.
Old 08-20-2012, 10:09 AM
  #29
Yup i used mobil 1 oil torqued down to 80ft/lbs worked really well
Old 08-20-2012, 09:03 PM
  #30
Charlie Murphy!
iregret's Avatar
Thanks guys. I'll just use Mobil 1 then! That's the oil I usually run.
I'll be replacing most of the seals in the engine. You guys think I should run conventional motor oil for the first 500 miles?
Quick Reply: eBay head studs
