Eaton/Magnacharger Question....
Old Sep 12, 2004 | 09:54 PM
moregrip's Avatar
what a rush!
Originally Posted by BenKey
I'd help you out, but there are 15 sheets of plywood in front of my toolbox where one is and can't get to it. (hurricane preps)
Thanks bro, My damn Radix is boxed up in storage, so I totally understand
Old Sep 12, 2004 | 09:56 PM
moregrip's Avatar
what a rush!
except I'm not prepping for a hurricane I mean, good luck with that!
I hope you got some big chains to wrapped around your axles....
Old Sep 13, 2004 | 12:07 AM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by moregrip
Do all Eaton superchargers use the same diameter snout shaft that you mount the pulley directly too?
What are you looking to do?
Old Sep 13, 2004 | 12:08 AM
moregrip's Avatar
what a rush!
replace the pulley
Old Sep 13, 2004 | 12:17 AM
BlownChevy's Avatar
blownerator
25 Year Member
Here is the place you can get them, I am sure you will get the picture
www.Desempeñodeagarre.com
Old Sep 13, 2004 | 12:19 AM
moregrip's Avatar
what a rush!
link doesn't work bro
Lone Chev's Avatar
Look's like .642 diameter with calipers. I can't remember what I gage pined it to but I have it at work if you need the excat number. Are you looking to make your own? Because nelson perfromance has down to 2.75 on the outside diameter. Myself I'm working on a 2.6 at work right now.
Old Sep 13, 2004 | 12:21 AM
moregrip's Avatar
what a rush!
yes, I need the exact measurement.
No, not going to make my own.
hold on a second and I'll show you guys whats up!
Old Sep 13, 2004 | 12:25 AM
moregrip's Avatar
what a rush!
OK, check this folks!
this is pimp!
The SuperGrip Supercharger Pulleys are uniquely designed to eliminate belt slippage and extend supercharger belt life. When a supercharger belt slips, power is lost. Belt slippage will prematurely destroy a supercharger belt. The slits and holes provide traction for the belt. They allow the air that gets trapped under the belt to escape to prevent a cushion of air from building up under the belt and causing it to lift away form the pulley inducing slip.
I need the measurement to see if this guys M62 pulleys will fit our MP112's
Attached Thumbnails Eaton/Magnacharger Question....-0033.jpg
Old Sep 13, 2004 | 12:28 AM
BlownChevy's Avatar
blownerator
25 Year Member
And you should ask yourself.......why dont magnuson and eaton use that style pulley? I mean it DOES extend belt life and help with slippage......NOT.
Been there, tried that.
