Eaton Install Tech Article
Old Dec 14, 2003 | 06:55 PM
agreif's Avatar
Default Eaton Install Tech Article
Hope it helps you if you need it. Let me know if you have any questions.
http://james.jaguar.net/agreif/eaton/eatontech.htm
Andrew
Old Dec 14, 2003 | 07:44 PM
KeukaZ71's Avatar
Andrew
thanks andrew. looks like the removal of the carrier was a PITA. also looked like you ran into a few unexpected obstacles too (visits to shops and garages). i bet the 2nd time around will be a piece of cake.
Old Dec 14, 2003 | 08:43 PM
agreif's Avatar
Originally Posted by KeukaZ71
thanks andrew. looks like the removal of the carrier was a PITA. also looked like you ran into a few unexpected obstacles too (visits to shops and garages). i bet the 2nd time around will be a piece of cake. i still have a few questions of course. what is the difference between bearing cups and bearing races?
Yeah, not having a vice is the main reason I had to go to the shops. if I had had one I would have been able to get the ring gear on and off. And the other reason was knowing the right way to get the eaton out and the shims in. Those things were really the only things that held me up. If it hadn't been for those this would have been a one day thing. Bearing races and cups - there is no difference.
chvy=power
Aug 31, 2015 10:51 AM
Raylar Engineering
Aug 26, 2015 10:36 PM
Denali08
Aug 9, 2015 04:34 PM
chvy=power
Jul 27, 2015 10:06 AM
