Which is easier?
Old Feb 3, 2007 | 10:18 PM
SSSBLKOUT's Avatar
Default Which is easier?
Swapping the cam with the heads on the car, or...
Pull the heads and do the swap?
I know that means new head gaskets, which at 120000K, isn' t a bad idea, but are the headbots TTY or can I re-use them?
Old Feb 3, 2007 | 10:23 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Does it really make a difference? I wouldn't pull the heads unless there's a problem with 'em, cleaning 'em, or you're having them modified.
Read through this link: Cam Swap Steps
That should give you a strong sense of what is involved with cam swaps.
Old Feb 4, 2007 | 12:21 AM
06WT's Avatar
Keep em on less problems to worry about
Old Feb 4, 2007 | 02:23 AM
LARRY01Z28's Avatar
alot cheaper to do just the cam swap. www.ls1howto.com is a great website.
Old Feb 4, 2007 | 02:29 AM
AustinDesigns's Avatar
I would keep the heads on. The bolts are TTY, and they are over $100 for another set, plus the head gaskets. Mine were like $150, but they are Cometic's. Don't know how much stock ones are. Right there you are already saving over $250!
Old Feb 4, 2007 | 06:20 AM
SSSBLKOUT's Avatar
Thats kinda what I thought I was gonna hear.
While we're on the subject, how much can you mill the heads before you have to worry about valve clearance?
Whats the stock comp ratio of the LM7?
If I can raise it a point, by getting the heads milled, at the same time that I am doing to cam swap, that would be a nice power jump.
Old Feb 4, 2007 | 06:22 AM
SSSBLKOUT's Avatar
this dude thinks hes got all kinds of money...
dumbass
Old Feb 4, 2007 | 07:38 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
LM7 stock CR is 9.5 to 1 iirc.
06murder
Sep 4, 2015 03:54 PM
spiritfish
Aug 24, 2015 05:04 PM
Sierra1320
Aug 15, 2015 08:04 PM
