e85 lq4
Old Dec 28, 2015 | 10:34 PM
Gypsy06vortecmax's Avatar
Default e85 lq4
not sure if I posted this in the rite spot.... I'm finishing my lq4 and 4l80e swap in my 2003 rcsb S10 and just need exhaust and a tune but before I get a tune I need to find out what injectors I could use to run e85 at all times I live rite next to a station that has it so why not... is there a factory injector I could get away with? I really don't wanna spend a lot of money its a budget build... future mods are cam, stall and some spray I already have the cam just not ready for that quite yet its a 228/232 112lsa 600lift
Old Dec 28, 2015 | 10:39 PM
FFDP's Avatar
Don't forget about the fuel pump aswell, E85 can require up to 30% more fuel.
But I'd think 40-50lb injectors for a NA motor.
And honestly I'd stay with 91+ pump gas for the mods you are doing, just makes life easier and a extra thing you don't have to buy. You'll also get way better gas mileage.
Old Dec 29, 2015 | 10:53 AM
gagliano7's Avatar
I know some trucks came withe the flex fuel so you will have no problem finding some injectors. As FFDP said you will need a good fuel pump.
Old Dec 29, 2015 | 11:51 AM
ezdaar's Avatar
Unles you raise compression substantially, install a turbo or blower there is no need for E85.
As stated it will reduce mpg considerably and require a fuel system far beyond what a "budget" build will ever need.
That said, i would still find some flex fuel injectors as your build will push the oem injectors on that LQ4 beyond their capabilities.
Might aswell aquire a complete nnbs flex fuel intake system to drop on that LQ4.
It will help alot in taking full advantage of that cam.
Old Dec 29, 2015 | 12:33 PM
madmann26's Avatar
FF injectors and pump is what you need, on a budget.
On my .040 lq4, I run about 68-70% IDC on the stock 5.3 FF injectors.
flatblack83
Jan 8, 2016 06:58 AM
04chevy2500
Jan 7, 2016 01:20 PM
JordanH
Dec 20, 2015 04:11 PM
sharpshooter
Dec 11, 2015 02:48 PM
chevydad
Dec 3, 2015 11:48 AM
