e fans stuck on
Old Jan 25, 2010 | 05:52 PM
  #21
EVILGMC's Avatar
the hot relay may have a shorted coil...which, if it is the low speed relay, could keep the fans on low. fry's has small metal enclosures for sale that could be used.
Old Jan 25, 2010 | 06:15 PM
  #22
SLOXCAB's Avatar
Sweet man thanks ill check out frys and let you guys know what happens with the relays
Old Jan 25, 2010 | 06:50 PM
  #23
budhayes3's Avatar
PT's Slowest Truck
Where are your relays mounted that they're taking on water? Mine are mounted to the PCM cover and they stay dry...I'm not real low to the ground though...I see you're 3/4...
Old Jan 25, 2010 | 06:52 PM
  #24
00ChevyScott's Avatar
Wearin' da big hat
I put my relays under the fuse box cover.
Old Jan 25, 2010 | 07:13 PM
  #25
budhayes3's Avatar
PT's Slowest Truck
That's the best spot...
Old Jan 25, 2010 | 07:16 PM
  #26
SLOXCAB's Avatar
They are mounted also on the cover but cali was hit with bad rain all last week that caused me to drive through some big *** puddles
Old Jan 25, 2010 | 08:03 PM
  #27
SLOXCAB's Avatar
update-i went a picked up a some new relays after work. they only had two so i only got to replace two of them but my main concern was the relay that got really hot today. The problem seems to be fixed but it bugs me that i have 2 gray relays and one black. Call me **** but that stuff bugs me. i have 4 more on order just incase other go out in the future
  #28
SLOXCAB's Avatar
Hey Scott can you post up a pick of where your relays are?
Old Jan 25, 2010 | 08:11 PM
  #29
GMCtrk's Avatar
I wouldn't use the el cheapo relays, they'll blow too easy. The blackbear ones are of higher quality, but you can't be having them in water.
Old Jan 25, 2010 | 08:13 PM
  #30
SLOXCAB's Avatar
where can i buy the same relays that justins sells?
