E-Fan wiring question...
Old Oct 6, 2006 | 04:38 PM
RoosterMcCandles's Avatar
Default E-Fan wiring question...
I got some LT1 e-fans in today and I am not real sure how to hook them up. They came with one of white1's wiring harnesses. The harness is very clean and looks like it would be pretty easy to hook up but I'm not real sure exactly where everything goes...I don't have any pictures right now but can anyone explain how everything goes?
Old Oct 6, 2006 | 04:55 PM
white1's Avatar
Sorry bout that.
The big ring goes to a +12V supply, the small ring is for a ground. The green wire taps into the dark Green wire for the A/C. Ill see if I have a pic I can send of that. And the PCM pin goes in slot 42 on the blue PCM plug
Old Oct 6, 2006 | 04:58 PM
A pic would be awesome...you make a VERY nice harness!!
Old Oct 6, 2006 | 05:06 PM
white1's Avatar
Lemme see if I can figure out how to do that. Im home alone right now.
Old Oct 6, 2006 | 05:13 PM
Sounds good...I'm kind of confused on the 3 'boxes' on the other end of the harness. Are those the PCM pins? Sorry for all the questions, but wiring isn't one of my fortes!!
Old Oct 6, 2006 | 05:16 PM
white1's Avatar
No, those are the relays. Ill PM you
Old Oct 6, 2006 | 09:15 PM
Phantom's Avatar
11 Second Club
I'll wire in them fans if you'll put my shift kit in...
Old Oct 7, 2006 | 12:53 AM
The wiring ended up being easy...just needed to know what each wire was for. Only took about an hour for everything. Shift kits are that tough, just tedious and time consuming. It also helps if you like the taste of transmission fluid!!
Old Oct 7, 2006 | 03:41 PM
Phantom's Avatar
11 Second Club
tried and failed miserably last night on the shift kit...gonna give it another shot this week
Old Oct 7, 2006 | 07:42 PM
Where did you fail at? To make it easier so you know your way around the tranny, see if you can find some material on the web about the internals to help you feel more comfortable.
