E-fan wiring
I currently have a 3-relay wiring on me e-fans-
PCM on = both fans slow - (wired in series)
AC on = 1 fan high
PCM & AC = 2 fans high
Is there a way were I can set the pcm to turn both fans on low at a certain temp and then both fans on high at a diffrent temp , like the 05 trucks have two temp setting for the fans,
Can I do this and how?
Thanks
AC on = 1 fan high
Thanks
How do I change this text
You Could buy another fan controler. That way you have two different settings for the engine...
I have mine come on both low at 170 with the aftermarket controler, then with pin 44 when the coolent gets to 195 both on high.
Wrecker 426
Sep 30, 2015 09:39 PM
