E fan PCM outs
Old Mar 5, 2005 | 08:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default E fan PCM outs
I am installing the fans tonight, and I know the blue plug uses PIN# 42....but there is a pin on the red plug that will control the low speed side of the fans.....anyone know what pin it is?
Old Mar 5, 2005 | 08:49 PM
XLR8NSS's Avatar
Adkoonerstrator
This is the first time I've heard that. I thought the second fan control pin was used for something else on the trucks?
Old Mar 5, 2005 | 08:52 PM
BlownChevy's Avatar
blownerator
25 Year Member
I was reading about it at work in the GM book, and I forgot the book
Old Mar 5, 2005 | 09:03 PM
XLR8NSS's Avatar
Adkoonerstrator
I have a Fbody and Truck PCM pinout in front of me right now.
Pin 42(BLU connector) on the Fbody is the Fan relay 1 control
Pin 33(RED connector) on the Fbody is the Fan 2 and 3 relay control
Pin 42(BLU connector) on the trucks is listed as not used. We use it though to control the fans just like the Fbody does.
Pin 33(RED connector) on the trucks is the HVAC recirculation door control
Old Mar 5, 2005 | 09:06 PM
BlownChevy's Avatar
blownerator
25 Year Member
There you have it.....I will let you know what happens.
Old Mar 5, 2005 | 09:14 PM
XLR8NSS's Avatar
Adkoonerstrator
What Harness are you using or is it a homemade one?
There a bunch of "not used" pins on the truck connectors. Which one might control a second fan setting I don't know.
XLR8NSS's Avatar
Adkoonerstrator
I wonder what pins the 05 trucks are using?
Old Mar 5, 2005 | 09:15 PM
BlownChevy's Avatar
blownerator
25 Year Member
I have my own PCM pins.....making the harness myself....not using the crappy controller that comes with the flex-a-lites.
Old Mar 5, 2005 | 09:16 PM
BlownChevy's Avatar
blownerator
25 Year Member
From what I have read/seen it is the pin 33
Old Mar 5, 2005 | 09:17 PM
XLR8NSS's Avatar
Adkoonerstrator
Go see if it's used already on your truck. My service manual is for a 2000 model year.
