E-Fan/Over Heating Issue?
#41
Yes...as per the above drawing...the signal from the A/C or in-cab switch simply energizes the coil of the relay. Relay's draw next to no current so you don't need to worry too much about the wire size there.
The actual wiring which passes through the relays to the fan motors needs to be substantial enough to carry about 50Amps. Also...make sure the relays are rated at same (or higher).
#42
#43
#46
Now I need to test this at night with all the lights on and see what happens.
Thanks.
#47
murderedSS
27
Oct 12, 2015 11:13 AM
MA$TER_E
Sep 9, 2015 03:14 PM
