The drone has got to go
Alright, so I just installed a Magnaflow muffler and tailpipe on my truck and it drones like crazy. What are some things to try to rid this? This is the muffler I went with http://www.summitracing.com/parts/MPE-12590/ It's located in the stock location. Everything is stock and runs up to adapter pipes which bring the factory 2.75" up to 3" where it meets into the muffler, then 3" single pipe all the way back exiting out the factory location. I've heard about angling the tailpipe down towards the ground aswell as angling it so it exits level but what else can I try? Initially it sounded WAY too loud for my taste so I had a buddy drive it around abit so I could hear it from outside and it sounds pretty good but on the inside the drone just makes it sound irritating and really loud
*Edit* 2000 Silverado 2500, 6.0l |
Most guys on here are running 2 mufflers to knock out the drone! Do a search I just read about one last night
1 Attachment(s)
Originally Posted by mhotrodscooter
(Post 4548547)
The thing is I don't think you'll ever be able to fully eliminate in cab drone when switching to any aftermarket muffler. But I think I did a decent job knocking it down with my setup (see pic) on my 6.0L. Im actually going to take some measurements and see if I can get a 12" bullet in front of my two 16" muffs, though Im almost convinced its not going to get any quieter. Im also thinking about sticking some dynamat to the sheet metal to the underside of the cab right above the mufflers to see if that will help any.......anybody tried this? |
weld dumps on the muffler that point toward the ground, that will help. Also, you can weld in an resonator or glasspack before the muffler.
Originally Posted by 02'Z71ONDUBZ'
(Post 4548581)
I have a bullet infront of my Borla Muffler dumped infront of the axle and I don't get almost no drone in the cab. As soon as I open the cut out to hear the Bullet all you hear is drone.
my 95 caprice droaned after running full duals all the way with flows, I added 15" glasspacks to each "no see ums" tail pipe ...................I hate tips
droan stopped car still had a sweet mouse motor growl |
(Post 4548581)
my corsa had some big drone to it, and i didnt like it at all, i ended up putting a dynomax bullet before the muffler, so i have 2 mufflers, and the drone is gone, and its so much nicer as well.
Originally Posted by 1sik02
(Post 4548674)
| All times are GMT -5. The time now is 04:23 AM. |
