Dreaming of 6 litres...........
Old 04-30-2018, 05:34 AM
  #21
madmann26's Avatar
At that CR, it's going to feel lethargic at best.
Use a .040 head gasket, that will get the CR into the upper 10's or if you're feeling really spiffy, use a Cometic .021 gasket.
That'll get you into the mid 11's for CR. With a good tune it would be completely safe but you'd probably have to run premium.
Old 04-30-2018, 07:58 AM
  #22
Mark Johnson's Avatar
Now that we know what your doing we can get a more accurate picture.
IIRC an LQ4 piston has an 8cc dish.
1st, Why bore the engine .060 over??? There is no advantage to that and the engine will actually run hotter the thinner the cylinders get.
2nd, Why .075 thick gasket? This will take away from the quench area and reduce compression lower to like around 9.2:1. Typically the factory pistons stick out of the hole on these Iron blocks. Each one is a little different I typically use .006 out of the hole for rough calculations. Ideally you would want to run around a .040 quench which is why the factory uses a .052 thickness gasket.
If you want a 9.7:1 ratio I would build an LQ4 with a .020 over bore with a factory head gasket and 69cc head.
I have a comp cams pushrod length checker 7702-1
It's the gasket that is 4.060 (don't plan to touch block bore) and .075 thickness allowed for my target compression with the heads milled to yield that 69cc combustion chamber. Hmm, but also didn't take into account the .006 outta the hole, or the 8cc dish. Thanks- gonna crunch some more.......
P.S. yeah, can I reuse the factory head gasket? Been looking at cometics and the smallest size I've found is 4.030 bore
Old 04-30-2018, 08:13 AM
  #23
Originally Posted by trxmxzx
I’ll be trying out a lq9 with 243 heads and a tsp stage 2 low lift truck cam on 93 oct. will be starting out with a lq4 base with 8 degrees of timing being pulled .... going for that iron ls2 power and it being my wife’s DD in a crew cab
Nice- keep us updated..........
Old 04-30-2018, 11:56 AM
  #24
Custm2500's Rude Friend
1FastBrick's Avatar
Factory head gaskets are much cheaper. There like 35-40 a piece Vs. the 80-90 for cometic.
Old 04-30-2018, 02:04 PM
  #25
Factory gaskets good enough- great! yeah- 69cc combustion chambers and the factory gaskets will get me to the 9.7x I want to be, overlooking the obvious.. Say, recommendations on a pushrod length checker...........
Old 04-30-2018, 03:20 PM
  #26
1FastBrick's Avatar
I have the comp cams pushrod length checker 7702-1
Mark Johnson (04-30-2018)
Old 04-30-2018, 05:53 PM
  #27
Oh yeah- am I gonna need those lite springs too..........
Old 04-30-2018, 09:26 PM
  #28
1FastBrick's Avatar
COMP Cams Valvetrain Checking Springs 4758-2
A whopping 3.99 currently....
When I got them, it was cheaper to buy them individually as they were like $7 at the time.
Individually they were 1.99 same part number with a -1 instead of -2.
Old 05-01-2018, 08:44 AM
  #29
whoa- 3.99, I'm gonna have to check the budget
Old 05-01-2018, 10:56 AM
  #30
1FastBrick's Avatar
Talking
You said budget....
Don't forget the fluids, new bolts, and everything else....
There is always something left out, whether it's forgotten or broken in the process.
Murphy's Law dictates this.
Quick Reply: Dreaming of 6 litres...........
